Exporting Projects to load in another WebODM
Using WebODM on multiple cloud servers for fast processing. Any way to include (in the future) a way to export projects to then import them on a different WebODM installation?
I do not want to use Nodes, as these systems are independent. I would like to be able to export completed projects and then add/import them to the WebODM installed on my laptop for usage/utilization.
Thank you.
That would be an interesting feature to add. Could you add it as a feature request on https://github.com/OpenDroneMap/WebODM/issues ?
Currently there’s no easy way to export/import single projects between WebODM instances.
Thank you Piero!
#4
Thanks for adding that issue! That will be a much loved feature, I expect.
