Exit on code 132
Hello ODM Team,
I installed ODM natively on my ubuntu 16.04 server. After installation I tried to test the odm with the auckerman dataset. It started well but stopped after meshing with MVS Textturing Cell:
[INFO] Running ODM Meshing Cell - Finished
[INFO] Running MVS Texturing Cell
[DEBUG] Writing MVS Textured file in: /home/derfred/ODMProjects/TEST001/odm_texturing/odm_textured_model.obj
[DEBUG] running /home/derfred/OpenDroneMap/SuperBuild/install/bin/texrecon /home/derfred/ODMProjects/TEST001/opensfm/reconstruction.nvm /home/derfred/ODMProjects/TEST001/odm_meshing/odm_mesh.ply /home/derfred/ODMProjects/TEST001/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none
/home/derfred/OpenDroneMap/SuperBuild/install/bin/texrecon (built on Jun 27 2018, 08:31:21)
Load and prepare mesh:
PLY Loader: comment PCL generated
Reading PLY: 100104 verts… 199788 faces… done.
Generating texture views:
NVM: Loading file…
NVM: Number of features: 0
Loading 0%…Illegal instruction (core dumped)
File “OpenDroneMap/run.py”, line 47, in
plasm.execute(niter=1)
File “/home/derfred/OpenDroneMap/scripts/mvstex.py”, line 139, in process
‘{keepUnseenFaces}’.format(**kwargs))
File “/home/derfred/OpenDroneMap/opendm/system.py”, line 34, in run
Exception: Child returned 132
So it exited with error 132. I checked the community pages and found out that this comes up when the hardware might be to old.
I’m running it on a HP proLiant DL385 G6 rack server with a six core AMD Opteron Processor Model 2435 (2.6 GHz) CPU and 62GB ram.
So is there any experience to handle this problem?
Rebuild the docker image.
docker build -t opendronemap/opendronemap .
This will take a few hours but it will be compiled for your machine.
I will give it a try. Thanks.
#4
@pierotofy I tried using the rebuild docker instead of the natively installation. It exited on the same point during meshing again with the 132 error as posted above. :frowning:
#5
Mm, I don’t know then. Possibly related: https://github.com/nmoehrle/mvs-texturing/issues/99
Could you open an issue on https://github.com/OpenDroneMap/OpenDroneMap/issues so that we can track this and add paste a link to this thread? If possible, it would also be nice to have a copy of the dataset you are using (if you can share / upload it on google drive or dropbox).
#6
Issue on github: https://github.com/OpenDroneMap/OpenDroneMap/issues/859
