Exception: Child returned 132
I’m attempting to run WebODM on my Windows 10 machine. I’ve managed to successfully install and run using Docker. Each time I’ve attempted to process my small photoset (which I’ve verified works with other services [PrecisionMapper]) the process quits just after “Generating texture views”. I’ve pasted the log below.
My computer is fairly antiquated at this point, running with only 4GB of RAM. I had thought that might be the issue, but in my GitHub searches I wasn’t able to identify anything from my log that pointed to memory as the issue. My Linux knowledge is essentially limited to Googling commands and mashing the keyboard until something works, so it may be a very simple issue.
The photo set can be found here: https://drive.google.com/file/d/14-4b4f-KwCA1Y-y87sD0fz3PNBhsp2Dv/view?usp=sharing
The log is here: https://drive.google.com/file/d/1fAxsNqvHCzCBU2m0Pw_4KdJs5-o4cR3W/view?usp=sharing
Any help would be most appreciated!
From: https://github.com/OpenDroneMap/WebODM#common-troubleshooting
Sympthoms: Task fails with Process exited with code null, no task console output - OR - console output shows Illegal Instruction - OR - console output shows Child returned 132
If the computer running node-opendronemap is using an old or 32bit CPU, you need to compile OpenDroneMap from sources and setup node-opendronemap natively. You cannot use docker. Docker images work with CPUs with 64-bit extensions, MMX, SSE, SSE2, SSE3 and SSSE3 instruction set support or higher.
Ah-ha! Thanks pierotofy, that answers my question nicely.
