Exception: Child returned 1 while --rerun-from opensfm
From @specyfick on Sat Apr 15 2017 14:16:31 GMT+0000 (UTC)
I have suffered today that problem.
I’ve executed first command:
python run.py --project-path /home/specyfick/ODMProjects/ --orthophoto-resolution 20 --rerun-from odm_orthophoto --force-ccd 6.17 ProjektLakiShort
All process went without any problem. Mesh was generated and orthophoto.
Unfortunately images rectification was not good and images have a small distortion remaining.
I wanted to correct K1 and K2 parameters in camera_models.json with camera_models_override.json file in /project/name/opensfm/ means in project folder.
I’m using Hero3 Black camera, and distortions parameters estimated by a ODM are not meet my requirements. I have got my own calibration results and i want to put them to a file.
As I understood, i can correct file above and rerun process again. I’ve rerun it with command:
python run.py --project-path /home/specyfick/ODMProjects/ --orthophoto-resolution 20 --rerun-from opensfm --force-ccd 6.17 ProjektLakiShort
So from from Opensfm.
No files corrected. Just rerun for test. And recieved error:
[DEBUG] running /home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon /home/specyfick/ODMProjects/ProjektLakiShort/opensfm/reconstruction.nvm /home/specyfick/ODMProjects/ProjektLakiShort/odm_meshing/odm_mesh.ply /home/specyfick/ODMProjects/ProjektLakiShort/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none
/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon (built on Apr 13 2017, 21:15:45)
Load and prepare mesh:
PLY Loader: comment PCL generated
Reading PLY: 493703 verts… 988845 faces… done.
Warning: Zero-length normals detected: 988783 face normals, 493568 vertex normals
Generating texture views:
NVM: Loading file…
NVM: Number of features: 0
Loading 100%… done. (Took 4.2s)
Building adjacency graph:
Adding edges 100%… done. (Took 2.992s)
1483159 total edges.
View selection:
Building BVH from 988845 faces… done. (Took: 284 ms)
Calculating face qualities 100%… done. (Took 2.623s)
Postprocessing face infos 100%… done. (Took 0.073s)
Maximum quality of a face within an image: 0
Clamping qualities to 0 within normalization.
Writing data cost file… done.
988845 faces have not been seen by a view.
Took: 15.171s
Generating texture patches:
Running… done. (Took 2.157s)
0 texture patches.
Running global seam leveling:
Create matrices for optimization… done.
Lhs dimensionality: 0 x 0
Calculating adjustments:
Received signal SIGSEGV (segmentation fault)Received signal SIGSEGV (segmentation fault)
Obtained 6 stack frames: 0x4de294 0x7fad0b8f74b0 0x47dce4 0x7fad0c0cd43e 0x7fad0bc926ba 0x7fad0b9c882d
Obtained 8 stack frames: 0x4de294 0x7fad0b8f74b0 0x47dce4 0x7fad0c0c9cbf 0x47b6b3 0x42846e 0x7fad0b8e2830 0x42a9a9
/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon(_ZN4util6system17print_stack_traceEv+0x34)[0x4de294]
(/lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fad0b8f74b0]
_ZN4util6system17print_stack_traceEv/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon[0x47dce4]
/usr/lib/x86_64-linux-gnu/libgomp.so.1(GOMP_parallel+0x3f)[0x7fad0c0c9cbf]
+0x/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon(_ZN3tex20global_seam_levelingERK8UniGraphSt10shared_ptrIKN3mve12TriangleMeshEERKNS4_8MeshInfoERKSt6vectorISB_INS_20VertexProjectionInfoESaISC_EESaISE_EEPSB_IS3_I12TexturePatchESaISK_EE+0x1993)[0x47b6b3]
34/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon(main+0xa9e)[0x42846e]
)/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fad0b8e2830]
/home/specyfick/OpenDroneMap/SuperBuild/install/bin/texrecon(_start+0x29)[0x42a9a9]
Segmentation fault
[0x4de294Traceback (most recent call last):
File “run.py”, line 46, in
plasm.execute(niter=1)
File “/home/specyfick/OpenDroneMap/scripts/mvstex.py”, line 109, in process
‘{keepUnseenFaces}’.format(**kwargs))
File “/home/specyfick/OpenDroneMap/opendm/system.py”, line 28, in run
Any help will be appreciated.
Copied from original issue: https://github.com/OpenDroneMap/OpenDroneMap/issues/545
From @dakotabenjamin on Mon Apr 17 2017 15:50:40 GMT+0000 (UTC)
Can you try deleting the odm_texturing folder and then running the same command? Also please post what version of ODM you are using. Thank you for the detailed post.
From @yjmenezes on Fri May 05 2017 20:01:46 GMT+0000 (UTC)
@specyfick
I am running: ODM ver 0.3 from git 2017-05-04 under Ubuntu 16.04
for me, opensfm crash and report:
[DEBUG] running PYTHONPATH=/mnt/OpenDroneMap/SuperBuild/install/lib/python2.7/dist-packages /mnt/OpenDroneMap/SuperBuild/src/opensfm/bin/opensfm mesh /mnt/odm_terra_nova/opensfm
File “/mnt/OpenDroneMap/SuperBuild/src/opensfm/bin/opensfm”, line 34, in
command.run(args)
File “/mnt/OpenDroneMap/SuperBuild/src/opensfm/opensfm/commands/mesh.py”, line 22, in run
reconstructions = data.load_reconstruction()
File “/mnt/OpenDroneMap/SuperBuild/src/opensfm/opensfm/dataset.py”, line 336, in load_reconstruction
with open(self.__reconstruction_file(filename)) as fin:
IOError: [Errno 2] No such file or directory: ‘/mnt/odm_terra_nova/opensfm/reconstruction.json’
File “/mnt/OpenDroneMap/run.py”, line 46, in
File “/mnt/OpenDroneMap/scripts/opensfm.py”, line 112, in process
(context.pyopencv_path, context.opensfm_path, tree.opensfm))
File “/mnt/OpenDroneMap/opendm/system.py”, line 28, in run
please, if possible, could you or someone test with my dataset ?
I have a good dataset, available here:
–force-focal 152.274 --force-ccd 206.322 --use-exif
thank you
#4
From @dakotabenjamin on Mon May 08 2017 14:33:16 GMT+0000 (UTC)
@specyfick any luck?
#5
From @dakotabenjamin on Mon May 08 2017 14:36:40 GMT+0000 (UTC)
@yjmenezes ill test that now
#6
From @specyfick on Mon May 08 2017 14:47:48 GMT+0000 (UTC)
@dakotabenjamin at the moment no time to test, but will do asap
