Error: Temporary directory "tmp" exists within the destination directory
Trying to process 56 images from DJI Phantom 4 on Windows 10 with docker using development server. Ram allocated for docker 4096MB and 3 core of CPU.
Option : Fast Orthophoto
[DEBUG] running /code/SuperBuild/install/bin/texrecon /var/www/data/1e6d4025-de97-4b76-b557-7540a2060c5b/opensfm/reconstruction.nvm /var/www/data/1e6d4025-de97-4b76-b557-7540a2060c5b/odm_meshing/odm_25dmesh.ply /var/www/data/1e6d4025-de97-4b76-b557-7540a2060c5b/odm_texturing_25d/odm_textured_model -d gmi -o gauss_clamping -t none --skip_geometric_visibility_test
/code/SuperBuild/install/bin/texrecon (built on Apr 25 2018, 17:10:13)
Temporary directory “tmp” exists within the destination directory.
Cannot continue since this directory would be delete in the end.
plasm.execute(niter=1)
File “/code/scripts/mvstex.py”, line 133, in process
‘{keepUnseenFaces}’.format(**kwargs))
File “/code/opendm/system.py”, line 34, in run
Exception
Child returned 1
Try removing the /var/www/data/1e6d4025-de97-4b76-b557-7540a2060c5b/odm_texturing/tmp directory and try again (or simply delete the task).
