DSM/DTM Elevation Different from GCP's
I added the GCP’s from my WebODM GCP fileto a layer in QGIS, then added the DTM (and DSM) to layers in Qgis, then extracted Contours from all and labeled. The Elevations from the point file are different from those extracted from the DTM/DSM. Any thoughts? Can I verify the values in WedODM?
This is the kind of thing I was hoping to do with WebODM… though my mapping knowledge, and surveying terminology knowledge is a serious impediment. Is it possible to offset the data in some way to correct for the difference in elevation.
I’m not expecting to settle for that. If I find my error, this should work out.
#4
I am curious if the GCP’s are used in WebODM to adjust the output to real world data or just used to locate them on the map.
#5
Every other software I’ve used uses GCP’s to improve the accuracy of the elevations, the Geo tags in the image metadata (exif) puts the images in the correct location
#6
My GCP’s are in EPGS: 6413, That means X, Y and elevation in US survey Feet, the EXIF Data from the Images is in Degrees, Minutes and decimal Seconds with elevation in meters.
Does Open Drone Map recognize this and convert or do I need to use another CRS for My GCP)'s?
#7
I recently discovered I was not actually using my GCP’s ( I thought all that was required was to place the GCP file in the same folder as he images and WebODM would correctly locate it) when I correctly select the GCP file I can’t successfully process.
#8
Still a lot of voodoo under the hood with webodm from my perspective… on the mavic 2 pro the coordinates are there in two different formats for sure. Not sure which its using nor what your exif data contains.
Curious where your gcp data came from in your graphic in your first post… evidently not from webodm.
What format are you using for your gcp?
from mavic 2 pro exif
GPS Altitude : 115825515.8 m Above Sea Level (this is the erroneous altitude data)
GPS Latitude : 35 deg 2’ 23.13" N
GPS Longitude : 82 deg 9’ 26.89" W
GPS Position : 35 deg 2’ 23.13" N, 82 deg 9’ 26.89" W
Latitude : +35.0397709
Longitude : -82.1574982
Absolute Altitude : +1.20
Relative Altitude : +91.20
#9
I’m a land surveyor, I generated the original GCP data (points) using our equipment (Centimeter level accuracy).
I also generated the GPS data on my images using a separate Multi-band single frequency GPS receiver (Emlid Reach) post processed against a CORS station to get a GPS fix for each image. Again, Centimeter level accuracy. (I capture the Image event in a log file using a “Hot Shoe” adapter attached to my Sony NEX 5N’s flash, I then Geo-Tag the images in Geosetter)
We record our survey data using Arkansas State Plane coordinate’s NAD83(2011) / Arkansas South (ftUS) (EPSG 6413)
My images (as are most images) are Geo-Tagged using WGS84 (EPSG 4326 most likely)
The two formats you mention are the same Coordinate Reference System most likely WGS84 (EPSG 4326) one in Degrees Minutes and Seconds the other simply Decimal Degrees
#10
@yawstick, the moderators edited my previous post. Evidently in an attempt to be funny I said something offensive. If you saw the unedited comment and it was offensive to you I apologize. I assure you it was not meant to offend and was meant to showcase my ignorance when it comes to photogrammetry and place you and I in a similar light.
#11
I did see it but not an issue for me but we sometimes forget what a far reaching platform the internet is.
