Doesn't write output
Hello.
Not sure what’s going on. First run ever with docker and ODM. Used both docker run options #1 and #2 from the odm wiki, and my own image batch as well as the aukerman package. It runs all the rigmarole and output looks reasonable. It just doesn’t write the output structure; no images, no nothing.
All I get is an empty odm_orthophoto directory.
I’ve tried absolute paths in the command, but nothing changes.
I’m on arch linux. permissions are wide open.
console output
Thank you.
Perhaps the volume paths (via -v) are not mapped correctly. Could you copy/paste the exact command you are using?
