Configuration system failed to initialize MS NET framework
I have installed WebODM and receive this error: Configuration system failed to initialize.
Entire details of error copied below.
Screen clip of error message:
I select Continue and WebODM did start and I was able to begin processing images. However, still run into another issue where there is no indication that the task has completed (another issue to note in a later topic).
I use FireFox browser and use Windows 10 professional.
Copied details of erorr below:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize —> System.Configuration.ConfigurationErrorsException: ‘.’, hexadecimal value 0x00, is an invalid character. Line 9, position 1. (C:\Users\colin\AppData\Local\MasseranoLabs_LLC\WebODMManager.exe_Url_vbkwkh5snaj4zd3epqkhzpzasirbawl3\1.5.7.0\user.config line 9) —> System.Xml.XmlException: ‘.’, hexadecimal value 0x00, is an invalid character. Line 9, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
at System.Xml.XmlTextReaderImpl.ParseText()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Configuration.XmlUtil.StrictReadToNextElement(ExceptionAction action)
at System.Configuration.BaseConfigurationRecord.ScanSectionsRecursive(XmlUtil xmlUtil, String parentConfigKey, Boolean inLocation, String locationSubPath, OverrideModeSetting overrideMode, Boolean skipInChildApps)
at System.Configuration.BaseConfigurationRecord.ScanSections(XmlUtil xmlUtil)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
— End of inner exception stack trace —
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e)
at System.Configuration.Internal.InternalConfigRoot.OnConfigRemoved(InternalConfigEventArgs e)
at System.Configuration.Internal.InternalConfigRoot.RemoveConfigImpl(String configPath, BaseConfigurationRecord configRecord)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.ClientSettingsStore.ReadSettings(String sectionName, Boolean isUserScoped)
at System.Configuration.LocalFileSettingsProvider.GetPropertyValues(SettingsContext context, SettingsPropertyCollection properties)
at System.Configuration.SettingsBase.GetPropertiesFromProvider(SettingsProvider provider)
at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName)
at System.Configuration.SettingsBase.get_Item(String propertyName)
at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String propertyName)
at System.Configuration.ApplicationSettingsBase.get_Item(String propertyName)
at WebODMManager.Properties.Settings.get_upgradeRequired()
at webodm.FrmMain.FrmMain_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3132.0 built by: NET472REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
WebODMManager
Assembly Version: 1.5.7.0
Win32 Version: 1.5.7.0
CodeBase: file:///C:/WebODM%20Manager/WebODMManager.exe
Win32 Version: 4.7.3056.0 built by: NET472REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.7.3151.0 built by: NET472REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.7.3160.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Hey @Mur :hand: thanks for reporting the problem. It seems as this problem happens when upgrading from an older version of WebODM Manager. I think it’s due to a recent update. I have reverted the installer files to a previous version, if you re-download the setup (press the link from your e-mail) and install it the error should go away.
If it doesn’t, please let me know.
Hello @pierotofy. My apologies for the wait. I did install the version you supplied in the weblink. I received what I think is the same error. I copied it out full below:
And to verify I used the correct WebODM version:
Error:
mscorlib
WebODMManager
System
System.Drawing
System.Core
System.Xml
enabled.
For example:
#4
I see. I’m going to investigate this further. In the meanwhile, could you try to close WebODM Manager, navigate to C:\Users\colin\AppData\Local\ and rename the MasseranoLabs_LLC folder to MasseranoLabs_LLC_old, then restart WebODM Manager? Does it allow you to go past the error?
#5
Also, would it be possible to get a copy of this file? C:\Users\colin\AppData\Local\MasseranoLabs_LLC\WebODMManager.exe_Url_vbkwkh5snaj4zd3epqkhzpzasirbawl3\1.5.7.0\user.config
It would help me troubleshoot this problem.
#6
@pierotofy
I seem to be making some progress following your instructions.
WebODM Manager is now downloading WebODM. I also received a “checklist” window before the Manager window opened and the download started. I will update you when the download ends or when I get back to the office later today.
Config file can be downloaded here:
https://1drv.ms/u/s!AsDrAVdsoyVVwWLlduZiFG0MGTgd
#7
@pierotofy
I have completed two processing tasks!
Thank you
Colin
